ms3 Is it a good cam!!! what do i need
car mods
k&n cold air intake
85mm throttle body
ls6 intake
kooks long tube headers and y pipe
slp exhaust
373 gears
Stage 3 transmission from perform-a-built
3000 stall
k&n cold air intake
85mm throttle body
ls6 intake
slp exhaust
373 gears
3000 stall
the setup your buying is the same 1 i just got and installed myself . i love it . only diff. between our cars is mine is a M6 w/ a ls6 intake and 4.10's in the rear end . it pulls like a **** up top . jst wish i had the extra $$ laying around to drop in a new set of heads.
LS1Tech Premium Sponsor
If you want a single chain we offer an IWIS chain as well as the LS2 chain for the same price. For double rollers, Rollmaster offers a full line-up to meet your needs. While you've got the pump off, it's a good time to go back on with the ported pump we offer. It gives you the benefit of more consistent flow of oil through the pump, and is shimmed to give you slightly more pressure as well.
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
