Pictures of my build - 01 Z28
Attached below is a partial list on the build.
TrickFlow 215cc CNCd heads - decked for 12.0 compression
TFS Valve Spings
Custon Cam - 247/251 .623/.623 113+3
Calles Forged Rods
ARP rod bolts
COMP Hi Performance Lifters
Yella Terra 1.7 Roller Rockers
Diamond forged Pistons (with valve reliefs)
American Racing 1 7/8 LT with bullet turndowns
Melling Oil Pump
NA 347 Motor
Vengance Ported 92mm Intake and TB
Custom Ram Air
Other Mods - Turbo 400 RMVB with Transbrake
Precision Shifter
Funny Car Cage - Cro-Moly
Kirkey Race Seat & 6pt Harness
Grant Quick Release Steering Wheel
Strange Front & Rear Drag Brakes
Billet Specialities Drag Wheels (Front & Rear)
S60 with 35 spline axles & spool (4.11 gears)
MT ET Fronts (26x4.5) & Rear (28X10.5)
QA1 Shocks - All four corners
Yank 4200 Stall
Custom Driveshaft
Full Suspension Mods.
Weight of Car should be 3100lbs with me in the car. Radio, Speakers, AC, HVAC, Seats have been removed.
We are hoping for low to mid 10's this Friday at KCIR.
Thanks,
CoopZ06
TFS Valve Spings
Calles Forged Rods
ARP rod bolts
Melling Oil Pump
NA 347 Motor
Custom Ram Air
Precision Shifter
Yank 4200 Stall
Custom Driveshaft
Thanks,
CoopZ06
Hope this helps out. The cert doesn't have anything to do with the window net. Just the actual cage itself. You'll be fine with the net how you have it now.
Just so you know, the window net could have went off the front edge of the funny car cage like ty_ty13 is talking about. If you go this route the window net must be a minimum of 10 inches long. This is how i build my cars. It just looks cleaner this way. what you have will be fine.
very nice looking car btw.
CoopZ06
