6.0?
6.0?
i just bought a 6.0 complete motor that came off a denali, im wondering what HP do these motor come with???? i have an ms3 cam in my ls1 making 423rwhp ...should i remove the cam and put it into the 6.0 or put a bigger cam in the 6.0???????
i'm doing the exact same build using an 04 2500 LQ4. it's an easy swap. although i'm using forged Wiseco pistons and Compstar rods because i plan to run nitrous. i am running the MS3 as well. if you run a large cam like that i would suggest you have all the supporting mods for it. i am using 1 7/8" LTs, FAST 95/95, 42lb/hr injectors, and lots of nitrous to make this cam work. the stock shortblocks are bulet proof. good luck with your build.
um you're def putting the horse before the wagon. what are your supporting mods? and who cares about the hp? what does it run at the track? it's very difficult to estimate horsepower. it's actually useless to do so. the only way to know is put it on the rollers. yes swap the cam into the 6.0. freshen up the motor with a new oil pump, lifters, timing chain, rod bolts, pushrods, etc. drop the heads, intake, headers, and accessories and she should be ready to roll.
