PCM controlled A/C 2003 Silverado, is it possible?
Old 04-22-2009, 05:31 PM
ls1nova71's Avatar
LS1Tech 10 Year
Default PCM controlled A/C 2003 Silverado, is it possible?
I'm not sure this is even going to be possible because there is no A/C request wires in the PCM harness. It looks like I would have to use the original switch on the dash for it to work, because it sends a signal through the serial data line to the PCM. Anybody found a way around this?
Old 04-23-2009, 09:11 PM
ls1nova71's Avatar
LS1Tech 10 Year
Nobody's done this?
Old 04-24-2009, 01:12 PM
Rodder's Avatar
maybe a different OS you can flash that does have an AC request pin?
Old 04-24-2009, 04:49 PM
ls1nova71's Avatar
LS1Tech 10 Year
Yeah, I'm thinking about changing everything to 2002, but haven't had the wiring diagrams side by side to see how much repinning it would take.
