Drag Racing Tech
Question about the Edelbrock elbow
Old 04-22-2009, 10:47 PM
Taubr Unit's Avatar
Default Question about the Edelbrock elbow
I seen a thread about a nick willams TB not bolting up to the edlebrock intake elbow. Is this true or no?? I need to buy one but now would like to know if its gonna work
Old 04-23-2009, 06:10 AM
tektrans's Avatar
From what I understand that intake elbow doesn't really perform that well compared to the sheet metal version.
Old 04-23-2009, 12:08 PM
tim99ws6's Avatar
Depends on the elbow, but I'd like to know what some of these sheetmetal intakes are actually flowing...
From Edelbrock:
flow is 860cfm @ 20.5" h2o . Our taller versions flow more air; #3848 (950 cfm) and 3849 (1,050 cfm) with a 90mm throttle body.
Old 04-23-2009, 06:06 PM
Taubr Unit's Avatar
Well i pretty much hated and didnt know the Edelbrock had a dividing plate inside the damn elbow?! So i just ordered one from Aaron@intakeelbows Paid a little for it but it should be worth it in the end!
Old 04-24-2009, 08:34 AM
tim99ws6's Avatar
Why did the divider bother you? I actually like the fact that it's there. The fact that most all sheetmetal's don't have it bothers me more. Check out this view from edelbrock of divider vs. no divider.....yea, I'll take the divider, haha. Plenty of people out there happy with the Aarons though, so you can't really make the wrong decision there!
[/QUOTE]
Old 04-24-2009, 10:13 AM
383lt1impala's Avatar
The sheet metal elbows gain up to 40hp compared to the edelbrock. Why don't u just put a 4 barrel.
Old 04-24-2009, 10:17 AM
tektrans's Avatar
Cool illustration but as far as the divider goes, I think it's only in there because the back of the elbow lacks a good angle down into the intake.
The sheetmetal one's I've seen kind of sweep up from the tb so you don't get all that air hitting the back of the elbow at a bad angle, instead it directs the air down and back forward a bit.
From that illustration the divider looks like a band aid for a bad initial design.
Old 04-24-2009, 01:49 PM
tim99ws6's Avatar
Definitely the best option here is a 4barrel. If i was N/a or nitrous, I would be running that. It's a no-brainer (if you have the fab skills to mod the cowl to fit it)
Old 04-24-2009, 06:26 PM
Taubr Unit's Avatar
i would use a 4 barrel but im going with a turbo so its not that crutial for me.
Old 04-24-2009, 11:01 PM
night ryder's Avatar
to answer your question, no it will not fit. the only tb that will fit the edlebrock elbow is the 90mm they make. some others might fit but i know the ls1 tb does not fit.
posted this so other searching will have a answer
Old 04-25-2009, 02:24 AM
BlackWS666's Avatar
100% true. I have the edelbrock elbow with a holley 90mm right know, and i had to do some drilling to make it work. The top 2 bolts will go in fine, but the bottom 2 are offset to narrow on the TB. Just drill out, buy a few 2 inch allen headed bolts with screws and problem solved, not hard.
As far as the elbow goes for design, I am convinced that the elbow is a quality piece that will hold up just as good as any 400+ dollar sheetmetal elbow. Save you money, and use it elsewhere. 40HP gains.......
Old 04-25-2009, 02:44 AM
9sec93's Avatar
i was using an edelbrock elbow (part #3849) with a FAST 90 throttle body so i dont see why a nick williams wouldnt work. bolted right up. actually the guy i sold my intake and elbow to is running a nick williams on it.
Old 04-25-2009, 08:15 AM
Race your car!
JL ws-6's Avatar
I would be intrested to see someone use the 4 barrel style with a carb hat.... blow thru guys do it that way all the time and they have NO problems making power. With no intercooling (love the carb for that)
Old 04-25-2009, 10:39 AM
we are talking about #3847 (the one that fits without any cutting).
Old 04-25-2009, 10:49 AM
BlackWS666's Avatar
I was refering to the #3848. Not the low profile one that gets smashed in the back. And with a little bit of cutting to the plastic sill, the 3848 WILL fit under a stock ws6 hood.
Old 04-25-2009, 04:25 PM
9sec93's Avatar
either way they should all have the same throttle body flange on them.
Old 04-25-2009, 11:55 PM
i dont think they do. it says right in the instruction that it requires there TB. i tryed out a fast 90 and it did not line up.
Old 04-26-2009, 10:42 AM
ryarbrough's Avatar
I had to drill and tap holes for the bottom two bolts on my fast TB.
I'm also not seeing a 40 hp gain between this and an aluminum elbow... maybe 5 or so, but what does it matter when I just make up for it with "extra flow" (read bigger pills in the carb plate).
Quick Reply: Question about the Edelbrock elbow
