Western Members - Can anyone help me fix a car problem tomorrow (Thursday)???
nhra-trans-am
04-23-2009, 12:14 AM
Can anyone tell what's wrong or maybe even help me fix my T/A tomorrow? I was planning on going on a trip this weekend, but now my car won't start. Here is the description of what's going on.
Copied from my other post:
Car won't start help please!!!!
My 2000 Trans Am 6speed won't start today. The key goes into the ignition fine and I can turn it back to power the accessories, but it will not move foward past the off position at all. Another thing I noticed is that the steering is not locked like it normally does, I can turn the steering wheel.
I tried starting in gear and in neutral, Moving the tilt, and turning the steering wheel a little. I also rolled the car foward a little and there was no change.
What could be causing this? Ignition problem? VATS?
TIA
SUCK MY SS
04-23-2009, 11:03 AM
vats wont physically lock anything on the column or ignition switch...
sounds like you need the entire ignition switch/column lock assembly...
i can tell you how to get around the ignition switch, but i dont really want to post it up in the open forum...
NVR_SPDS
04-23-2009, 07:53 PM
Try turning the wheel to see if it will lock. I would think it should. Maybe its just a fluke, where you have the ignition lock, and wheel in a certain position that it wont work.. Cant hurt to try.
ZexGX
04-23-2009, 10:43 PM
I have this same problem on my Jeep. The Jeep came with a GM column from the factory (it's a 87). Pretty sure the column or lock assembly has to be replaced... Any other ideas (aside from hot-wiring your own car)?
nhra-trans-am
04-24-2009, 12:07 AM
Thanks. Thats what others have told me too. Can you get the parts diagram and part number for me by chance?
Thanks.Tried that too, still didn't work
Seems like that is the only option.
ss.slp.ls1
04-24-2009, 12:51 PM
You could probably get a whole steering column w/ keys from a parts car and swap the whole thing in.
lowerthanyou00
04-24-2009, 10:18 PM
work cept for vats:bang: less u get the right key:secret2:
XpEdItIoUs
04-24-2009, 10:50 PM
WOW, Why didn't you call me gilbert. Call me and i will grab my pry bar and head over jk. But seriously I will take a look at it.
SSMOKIN_Y2KSS
04-24-2009, 11:18 PM
wont work..the bcm wont accept the new lock cylinder...unless u take the bcm n shit with the column...
XpEdItIoUs
04-24-2009, 11:27 PM
Not if you swap out the lock cylinder, But you can always use a resistor or tune vats out.
ss.slp.ls1
04-25-2009, 06:03 AM
Yeah, either take the matching BCM or bypass Vats with a resistor, either one is very easy.
nhra-trans-am
04-25-2009, 11:42 PM
Thanks, I was actually going to call you, but I just took the Fiero instead. I just got back so I will call you soon
