Codes for my LT4
Codes for my LT4
Okay I went and pulled the codes off my car. I already put a new crank sensor on the car as it was pulling that code and still is. I cleared the codes but these are back.
Codes are:
P0118 - Engine Coolant Temp Ckt high input - Could someone elaborate on this?
P0335 - Crankshaft Position sensor A circut malfunction. -has a new crank sensor installed.
P0336 - Crankshaft position sensor A ckt rng perform.
P0443 - EVAP cntrl system purge valve C fault - I think that's part of emissions that was pulled off the car.
Codes are:
