Sponsored by: DashLynx
What do you guys do about scratches in the engine bay?
Old 10-29-2003, 09:14 AM
SloppyRob's Avatar
Default What do you guys do about scratches in the engine bay?
I have some various scratches on my firewall and fenders from wrenching (mostly from my LT install a year ago). I didn't think these little scratches went through to the metal but i believe there is a slight hint of rust in the scratch. Some of em are in hard to reach areas on the firewall. Should I try lightly sanding them with something and spray the area with underhood black, or I also have por-15? I know im being **** as these scratches are really really tiny but what do you guys think?
Old 10-29-2003, 11:23 AM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
Depends, you can use touch up paint but if the engine bay is black you could use some POR-15 to seal the area.
Old 10-29-2003, 12:21 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have used touchup paint, and you can barely tell.
The trick to touching up scratches, per my buddy, is to take a piece of thin cardboard, cut it at a sharp angle and just dab a little paint on the tip. Much more precise. Model paintbrushes are too much they make globs.
Old 10-29-2003, 01:27 PM
SloppyRob's Avatar
This is a good idea! I'll prob try this with some por-15. Thanks for the tip.
Old 11-02-2003, 08:02 AM
Z06PSI's Avatar
Toothpicks work also for small chips and scratches....
