600 rwhp ideas
Old 04-27-2009, 08:51 AM
Bad98SS's Avatar
Question 600 rwhp ideas
I have a ls1 camaro. Does anybody have any ideas how to make 600 rwhp on straight motor no bottle supercharger or turbo. Thanks
Old 04-27-2009, 08:54 AM
1CAMWNDR's Avatar
More cubes. Good heads. Right cam. Good exhaust.
Old 04-27-2009, 08:55 AM
ssick1's Avatar
yup
Old 04-27-2009, 09:12 AM
goober35's Avatar
lots of $$$$ will work also.
Old 04-27-2009, 10:37 AM
9secondsflat's Avatar
lsx454 will do it..
Old 04-27-2009, 10:56 AM
99blancoSS's Avatar
^^ Yep our LSX 454, LS7 457 or LS2 460 long blocks will put you there n/a on pump gas. It can be done with a solid roller 408 as well but the bigger the engine the easier it makes the power and the less hard it has to work.
Old 04-27-2009, 11:09 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We've built several 454 LSX motors that make well past 600rwhp. I believe with a aggressive 418 LS3 with PRC 237 heads you could get close to 600rwhp on a budget. I finished a few of those that made between 670-700 flywheel hosepower!!
The PRC LS7 heads on a 454 LSX engine we dyno tested made over 750flywheel hp on pump gas!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 04-27-2009, 11:18 AM
Bad98SS's Avatar
Alright, well what can i do with the ls1 engine to get max hp but keep it streetable just for the weekends.
Old 04-27-2009, 11:58 AM
conan's Avatar
Heads, cam, intake manifold, headers, full exhaust. On a 346ci ls1 450rwhp(+-) To get into the 500-600 rwhp with a 346ci you'll need forced induction or some go gas, But for those power levels forged internals are very encouraged if you want the bottom end to live.
Old 04-27-2009, 12:30 PM
stumprrp's Avatar
I'd guess 12 to 1 compression.. 240 plus cam.. 205 plus heads and a ported fast
