Tranny Trouble
Old 04-28-2009, 11:34 PM
WANNABE GENIUS
wannabess00's Avatar
Default Tranny Trouble
Just blew out my rear end at the track last weekend on my 2000 camaro and had the gears swapped back to stock. When we drove the car it had a wierd delay as if it was having trouble moving fluid inside the tranny. No leaks but the tranny fluid is dark and smells burnt. Anyone ever had tranny issues after blowing out the rear end at all?? Trying to figure out why the delay
Old 04-28-2009, 11:42 PM
LS1Tech Sponsor
performabuilt's Avatar
The low rollers are bad to break or seize along with the unout sprag, The input sprag seized will cause the band to burn up in 4TH gear killling it and the 3-4 clutch in pretty short order
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-28-2009, 11:59 PM
WANNABE GENIUS
Sounds like what it must be. Problem was noticed while the car was is overdrive and the car seems to be as healthy as can be in every gear except overdrive. Works just fine in reverse as well. So the low rollers are bad is what youre figuring? We were wondering if maybe a seal blew. And the input sprag as well?
Old 04-29-2009, 12:06 AM
LS1Tech Sponsor
well if the worse is in 4th its likley the input sprag , However in a failure like that I would replace both the low roller and the inputs sprag and if the input sprag is seized I would also carefully inspect the input drum or replace it. Since its is also a weaker part and would have also taken a very hard hit.
__________________
Call 888-744-6542
Old 04-29-2009, 12:10 AM
WANNABE GENIUS
looks like I get to pull a tranny...again lol! How much of a pain is that normally to replace. Im gonna have to have a tranny place around here do it. Just curious???
Old 04-29-2009, 09:05 AM
LS1Tech Sponsor
To do both its a complete tear down and reassembly.
__________________
Call 888-744-6542
Old 04-29-2009, 09:31 AM
WANNABE GENIUS
So really just a rebuild?
Old 04-29-2009, 09:39 AM
LS1Tech Sponsor
The proceedure would be very close to a rebuild .
__________________
Call 888-744-6542
Old 04-29-2009, 10:14 AM
WANNABE GENIUS
lol! good thing I dont have $1400 lying around
Old 04-29-2009, 10:17 AM
LS1Tech Sponsor
LOL I guess
__________________
Call 888-744-6542
