Timing and AF on spool M6 5.7 LS1
Is the theory Rich AFR on spool and lower timing correct or ?
read both sides of argument.
what do you dial in from cruise, part and high map(pre boost) with AFR and timing.
my 5.7 sbe M6 is set to 11.5 at 105kpa...leaving power or good safety margins....?
only boost to 8psi
regards
gav
The mantra on low timing, lots of fuel really comes from a specific boost building tune. This type of tune though, you have to retard timing so much (like -10 to -20 deg) that you are actually sending the fireball out the exhaust valve (which is why you add fuel). This will build boost very quickly, but it should only be used connected to a lag button or some sort of launching scheme. Otherwise, just ignore it, it is for a very niche boost-building circumstance or engines that have half your cylinders.
Just keep you timing as high as you can go and a/f around 13.5-14.0 (ramp to 11.5 once boosted) and you will build boost quicker for a street car.
Everyone I've showed the tune to has commented that the timing is very aggressive out of boost and the assumption is that it's to light off the turbo which for being a big *** 84mm it lights off pretty fast.
Thought I remembered you are on the China GT45 turbo too, right? Those are notorious for slow spool, even when all the tune parameters are “happy”. Its just a heavy wheeled dinosaur of a turbo.
If you are only running 8psi… that’s a pretty bad match turbo wise. A much smaller S36xx clone would run circles around it spool wise and make more power per pound. So would man other cheaper units.
You want just enough turbo to meet your goal. A 65mm ptrim exh wheel paired to a 60-70mm compressor would work ok and still be dirt cheap w china clones. The s366 I rode along with in a 5.3 was alight switch and crazy fun. It as a 66/73 turbo with a .81 t4. Ran well and was well into the 550whp territory. Suuuper snappy. ITs what i'd want with a manual trans.
I don't.
5.3
s485
I’d be looking for around a 66mm compressor unit with a p-trim 65mm or larger exh wheel. VS racing sells a 67/65 and a 61/65 for 319 shipped last I spoke to them. Have to email and ask about their “p-trim” line of turbos.
Any of the S366 line or clones of the S366's would work well and should be under $800. I'm sure Borg/Airwerks has a presence in the UK?
Any good? Guessing it will be almost as heavy as my gt45?
You don't want to see daylight between your turbine blades like these clones. I'd ask to see a shot of the turbine blade. Otherwise.... that is probably fine. Def better than the Gt45
yes have mapped engine out of boost a lot and had to back off in certain areas one or 2 degrees due to knock. Having seen any knock at all in boost though yet which I suppose is good.
regards
gav
