ahhhhhh!!!!!!!!!!! You will not beleive this
Old 04-30-2009, 09:07 PM
red-_-z28's Avatar
Angry ahhhhhh!!!!!!!!!!! You will not beleive this
After spending 20 hours working on my car i finally put it all together just to start it up and hear ANOTHER FLIPPIN KNOCKING SOUND!!
I swear i have no luck!
It sounds like its coming from the torque converter..is that possible? Its a very loud and rapid sound. And sometimes can be inconsistent.
Im planning on just sending it to GM so they can handle this. I cant stand this any longer. im only 16 and on my birthday i couldnt drive me car and now 8 days later still cant!
Im guessing they money i earned for my headers and cat backs will not be wasted at GM..
Old 04-30-2009, 09:10 PM
duh
duh's Avatar
does the sound increase with rpm? Could be a few things, but if it sounds like it's coming from the tq conv. it could be the flex plate. If it has a crack in it, it'll make that sound...had a cutlass do that to me once
Old 04-30-2009, 09:22 PM
red-_-z28's Avatar
actually the cover thats covering the tq conv? its happens to be missing when i bought the car :O
red-_-z28's Avatar
and yes it increases the higher RPM
Old 04-30-2009, 09:37 PM
shbox's Avatar
LS1Tech 10 Year
Without knowing what work you were doing to your car, suggestions will be limited to wild guesses.
Old 04-30-2009, 09:43 PM
red-_-z28's Avatar
okay well wheni got the car i had a strange rattle. It was coming from the rockers. I looked at that then notice one of the rockers would not tighten right. So i took of the intake and replaced all lifters. Also bought and replaced new opti, plugs, wires.
When i got the car i noticed the cover for the torque converter was missing. So im assuming something has been done to it.
But what i found strange is why would it just start randomly knocking once i start my car? Its been sitting for about 3 weeks.
The sounds is very loud but once you listen from under the car it sounds even louder..
any help?
Old 04-30-2009, 09:54 PM
Abdullah's Avatar
any help?
did you try to see if the blots of the converter are bolted there with the flywheel? that happened with me when i did some work on my previous 94 Z28 camaro when the car was not moving when i shift to D or R but there was no knocking or bad sound. hope that helps some.
Old 04-30-2009, 11:41 PM
1badzee's Avatar
Sounds like the torque converter bolts either backed out or the flexplate cracked. The conver you are talking about is not important - it will not cause damage not having it. Since it's already off, inspect the converter bolts/flexplate. My jeep had the same issue - sounded like engine knock.
Old 05-01-2009, 11:51 AM
ss.slp.ls1's Avatar
My buddy's car had a loud intermittent noise from the flexplate/converter area...then his flexplate cracked in three places not too long later.
I would drop the trans, pull the converter and inspect the flex plate. If it looks good, start the car and see if you still hear any knocking.
Old 05-01-2009, 11:04 PM
myltwon's Avatar
cracked flexplate or a backed out convertor bolt hitting the flextplate
Old 05-01-2009, 11:09 PM
Abdullah's Avatar
check the converter and flywheel bolts if they are tightened well or not. also check for if the flywheel is cracked or not.
Old 05-01-2009, 11:17 PM
Ponch95's Avatar
My young friend...MOST of US LT-1 owners really do feel your pain and frustraton...but there are yonder pastures with back highways when you are finally done.
Old 05-02-2009, 12:18 AM
James Montigny's Avatar
AMEN!
Don't get discouraged, the frustration is part of the game.
Anyone who tells you it always goes smooth is either lying or needs to start playing the lotto.
Old 05-02-2009, 12:22 AM
LM97Z's Avatar
[QUOTE=red-_-z28;11523392
any help?[/QUOTE]
My guess & "its just that" by you saying it "just started" i would have to say a spun bearing, flexplates just don't rip apart that fast, sure the bolts can come loose, but its more of a "load" rattle then a knocking sound, its higher pitched, i would lift it up some (support it with jack stands", then either use a broom handle or stethiscope if you can reach the oil pan, then listen, you'll know if its coming from the lower end, you can useally feel it with just your hand, let us know what you find either way.
Old 05-02-2009, 02:14 PM
joelster's Avatar
LS1Tech 10 Year
x2 on torque converter being loose. You said it was intermittent, which would rule out a bearing. You probably tightened down the torque converter really tight, but in fact you didn't actually bottom out the bolts, which would cause it to wobble around slighty.
Old 05-02-2009, 03:22 PM
red-_-z28's Avatar
its a spun bearing!!
Old 05-02-2009, 03:28 PM
crzytown69's Avatar
sorry to hear that bro
Old 05-02-2009, 07:13 PM
LM97Z's Avatar
Sorry to hear that, but from what you discibed, i figured that was it.
Old 05-04-2009, 11:47 AM
ss.slp.ls1's Avatar
Been there....
Time for a forged 355/383.
Old 05-05-2009, 05:13 PM
red-_-z28's Avatar
yea idk about all of that
im on somewhat of a budget
Quick Reply: ahhhhhh!!!!!!!!!!! You will not beleive this
