Stock TB is sticking.. How to fix??
take the TB off and check for spots the blade may hanging on. also check to make sure the rod the blade attaches to didn't somehow get bent. Taking the TB completely apart is easy and needs only basic tools
Moderator
Question whether it is the blade (which should not just up
and go bad) or some source of bypass air (PCV, stuck IAC,
manifold vacuum leak, etc.).
If you force it shut by hand that ought to settle the blade
question.
question.
