my new best 10.22 :-)
05-02-2009 18:01:35 Wind from SE at 5 mph, gusts to 7
Station local - Elev : 23 ft Temperature 86.20°
Barometric Pressure 30.01 Humidity 43.00%
Standard Rel Air Density 95.21% Track Rel Air Density 95.30%
Effective Altitude 1682.10 ft Tail Wind 2.00 mph
TIME-LR T
Right Lane
Class GM
Q/P 0
Dial In 0.00
R/T .457
60' 1.399
330' 4.132
1/8 6.463
MPH 104.810
1000' 8.490
1/4 10.220
MPH 129.93
i think i should be able to hit 10.0's once the air cools down
thanks everyone!
the setup is
stock bottom end ls1, ls6 hand ported heads, 224/224 .589 .589 112 cam, ls6 intake stock t/b, kooks 1 3/8 LT tr6 plugs, but here is the kicker NX 200 wet shot
this was only my 2nd time going i and started going to the GM challenge's every month. i really only go on saturdays. i have been fellowing your setups for a while now, been wanting to meet up with you to talk about ur past LS2 setup. maybe soon i will head up there on a friday.
thanks my best has been a 1.32 i have to thank madman for that
the setup is
great pass, very similar to my ms3 cam only times. air really doesnt effect nitrous like na though so you wont pick up much if any.
I also think you should go to a colder plug with that setup. might not see alot of gain but longevity will help im sure. you need a non projectd tr7 or maybe 8's
good luck
good luck
good luck
good luck
well the car was set up for a 100 shot, and i am still on my motor tune. to be honest i didnt think the motor would make it but i have about 15 pass on a 200 shot mostly 1/8 mile, and its still running so i am scared to chage anything lol
i have gone a best of 11.73 i cant recall the MPH right now, i have a th350. how did you know i was running a A3?
i like the TH400 with a small 224 cam combo. it clearly works.
if you are not detonating. if you are on an n/a tune up, you are likely high 20s degrees of timing at WOT. that is way too high on a 200 shot. you need to readdress your timing and plugs (likely) if you want to keep the motor alive on a 200 shot.
your car will likely go faster. this has been talked about a bunch of times in the nitrous forum. a 200 shot will create a LOT of cylinder pressure for a motor on a hot plug and high amount of timing advance.
anyone want to buy a LS1 long block... it has gone 10.22's
