Stock Block Redline...
Old 05-07-2009, 03:53 PM
Section 8's Avatar
Default Stock Block Redline...
Using a GM crate engine, how far can you push the redline with a weekend car (not DD) in NA form?
I guess the question really boils down to if you run out of rod/bolt strength before you run out of drivability with a fat cam I'd like to use the GM computer, but am not adverse to programming with something from someone reliable.
Is 6800-7000 going to tear itself up?
