Harland Sharp RR on 243's... Clearance Issues?
Old 05-07-2009, 04:53 PM
SLCKLS1's Avatar
Default Harland Sharp RR on 243's... Clearance Issues?
Hey all, I am going to be running some Harland Sharp Roller Rockers in 1.7:1 ratio and I am wondering if any of you have had any issues with both valve cover clearance (do I need spacers?) and head wall clearance (The 853's I test fit them on needed a bit of clearancing)
Im more worried about the valve cover clearance. Anybody having any issues?
Thanks!
Old 05-08-2009, 07:49 PM
SLCKLS1's Avatar
Anyone?
Who is running aftermarket rockers, which ones are you running and do you need valve cover spacers? If so, what lift is on the cam?
Old 05-08-2009, 08:51 PM
Tee1up's Avatar
Default harland sharp
Im running these rockers on my 403 and had to grind a little on valve cover
due to some interference and that solved the problem
cam has 640/644 lift
