Truck manifolds... Gaskets between manifold and crossover pipe..
Old 05-08-2009, 10:47 AM
lt1camaroman93's Avatar
Default Truck manifolds... Gaskets between manifold and crossover pipe..
What are you guys using for gaskets between the manifold and crossover pipes when using truck manifolds? I picked up stock gaskets for a truck any they are a metal ring and don't seem like they will work with this setup.
Old 05-08-2009, 10:53 AM
Restricted User
98Z28CobraKiller's Avatar
I did the same thing. Turns out, you dont use gaskets. Just a little red rtv. No leaks for me so far.
Old 05-08-2009, 11:14 AM
smokinHawk's Avatar
i used the black high temp rtv, no problems.
Old 05-08-2009, 11:49 AM
98turbls1's Avatar
I got a set of copper gaskets from Kurt (former wheel 2 wheel guy). They were pretty cheap and you can reuse them afterward.
https://ls1tech.com/forums/forced-in...collector.html
Old 05-08-2009, 03:21 PM
dreamls1's Avatar
+1 rvt
Quick Reply: Truck manifolds... Gaskets between manifold and crossover pipe..
