LQ9 rotating assembley
Complete LQ9/LS2 rotating assembly
The LQ9 I purchased is gone to ****, the crank might be beyond repair, the rod ends are out of spec and I dropped one piston and nicked the edge. Even if you have one good piston out of an LQ9 then let me know! I would LOVE to find the rods and pistons still attached... It would be even better if someone had everything in good condition!
The LS1 that is in the car now sounds worse than anything I have ever heard and I assume I will need a crank at the very least. It squeaks and squeals, but I may get lucky and be able to salvage everything. I rather get some parts lined up just incase though.
Let me know what you have! It must not be junk, I need this to rebuild my DD. I might consider an aftermarket assembly for the LQ9 if it's at the right price.
Bump... No LQ4 parts please. I would really prefer a stock, usable LQ9 rotationg assembly. I know someone here has one they will part with!! Hell, I don't mind if the crank needs to be turned .010.
