LS1 coverter to LT1
Old 05-09-2009, 07:12 PM
dhdenney's Avatar
Default LS1 coverter to LT1
Helping a buddy of mine do a TH400 swap. He's picked up a sweet package but the converter is holding it up. It's an LS pattern. Obviously they make dual pattern LS1 flexplates but is there a dual pattern flexplate for LT1?
Old 05-10-2009, 08:19 PM
FearMe222's Avatar
Not sure if they make a duel pattern flex plate or not, but the hub ( the piece that fits inside the crank) on the front of the converter is longer for an LS1, so you will also have to change that, if you didn't already.
Old 05-10-2009, 08:35 PM
dhdenney's Avatar
He was gonna cut it off with a band saw, got it covered. The bolt pattern is something we didn't think about it til we laid it on one.
Old 05-11-2009, 12:03 PM
WS Sick's Avatar
lay it up together ,mark and dril the flexplate. Use bolts nuts and lock washers to hold it together if it has tabs instead of threaded lugs on the converter.
also check your spacing you may need to shim it , make sure the flex plate when bolted to both the crank and converter is not in a bind or distorted.
Old 05-11-2009, 06:35 PM
dhdenney's Avatar
Wasn't really an option that we could see. The holes were falling in and around holes and ridges...... Doesn't really matter now. He called TCS and they said they'd go through it, change the cover for the right pattern and pilot, and put in fresh bearings for $200. He said ok!
Quick Reply: LS1 coverter to LT1
