72 forumla stock gauges
Old 05-10-2009, 11:58 AM
minytrker's Avatar
Default 72 formula stock gauges
I just finished up a ls1 swap into a 72 formula and want to use the stock gauges. I have all the stock senders installed in the ls1 and have a adapter box for the speedo. I need to know what wires do the tach, temp, and oil pressure. The car also had two temp sensors on the old motor, one with a single wire and the other with like 4 wires, which one of those is for the temp gauge?
Thanks
Old 05-10-2009, 03:46 PM
minytrker's Avatar
I basically need a wiring diagram for under the hood for the stock harness.
