Spohn Crossmember and 3 inch True Duals
Old 05-11-2009, 06:37 PM
93 black t/a's Avatar
Default Spohn Crossmember and 3 inch True Duals
I was wanting to run 3 inch true duals on my new setup, and was wondering if they'd clear with my Spohn crossmember for my torque arm. It does have the drive shaft loop also.
Old 05-11-2009, 07:28 PM
LT1
LT1's Avatar
Do you have the stock length torque arm?
Which Spohn crossmember did you buy?
Old 05-11-2009, 08:13 PM
wrd1972's Avatar
Doubt it.
Old 05-11-2009, 11:06 PM
I bought the spohn torque arm as well. The cross member as the bend for exhaust. Here it is.
http://www.spohn.net/shop/1993-1997-...ersY-Pipe.html
Old 05-11-2009, 11:24 PM
LT1
LT1's Avatar
In my opinion its better to run a transmission crossemember mounted torque arm for true dual exhaus system, because it gives good clearance.
Here's a picture of it
Old 05-12-2009, 03:54 PM
ABA383's Avatar
I run the Spohn TA with the cross brace and 3" TDs with an X that actually goes thru the TA cross brace...And I run two DS loops...One front, one rear....I posted pictures of it on here a while ago...Its all custom, but definitely doable...
--Alan
Old 05-13-2009, 12:56 AM
--Alan
Right on. I knew someone had to have tried it before I'll search to see if i can find it.
Old 05-13-2009, 01:14 PM
ABA383's Avatar
Here's the old thread...Scroll down for the pix...
--Alan
https://ls1tech.com/forums/lt1-lt4-m...rue-duals.html
Quick Reply: Spohn Crossmember and 3 inch True Duals
