AI 200cc 383 start-up vid inside.
Old 05-12-2009, 07:22 PM
RamAir95TA's Avatar
Default AI 200cc 383 start-up vid inside.
Well, it's finished. For those of you who recall my build thread from a few weeks ago, the motor is all finished. Swapped the old motor out in 2 days and it fired literally on the first crank. Hooray! The car is a little worse for wear (has sat for 5 years) so it's a little cruddy, but in sound mechanical condition.
Engine-
Gil Davis Racing-built 383 (.030" over, 3.75" stroke), factory 4-bolt block, Clevite H-series bearings, forged crank, forged Scat 6" rods, SRP forged -5cc pistons, zero-decked block, Canton 242T oil pan, Melling 10552 oil pump, Superdamper, Advanced Induction ported 200cc Dominator head package with .028" gaskets (results in 12.4:1 static compression), custom hyd. roller cam, Cloyes double-roller, LS7 lifters, Crane Gold 1.6s, TF chromemoly pushrods/guideplates, Canton valve covers, strip ported intake manifold (powdercoated metallic green to match the car), 42# Delphi injectors, Holley 58mm throttle body, CSI electric water pump, LPP long tubes/y-pipe to a cutout, Jegs Protorque starter, stock MAF, PCMforless programming.
Video clip:
Comments and opinions welcome. Enjoy.
Old 05-12-2009, 07:23 PM
Moderator
JasonShort's Avatar
Great stuff! Good choice of parts/combo.....should make some impressive numbers when tuned
Jason
Old 05-12-2009, 07:37 PM
AChotrod's Avatar
Sounds real good!! Congrats on gettin her done!
Old 05-12-2009, 07:42 PM
Tireburnin's Avatar
Looks nice. I love the feeling of the first start up.
Good luck ironing it out and having some fun.
Old 05-12-2009, 07:49 PM
96blkform's Avatar
Sounds like a very nice combo Should make some great numbers.
Old 05-12-2009, 07:54 PM
gregrob's Avatar
Wow dude. Wow...
That thing sounds like a BEAST
Old 05-12-2009, 08:07 PM
Elliott's94Z's Avatar
Very nice bro! Let us know what it puts out after you get it dialed in.
Old 05-12-2009, 08:21 PM
ss.slp.ls1's Avatar
Very nice.
94Z28rag's Avatar
We had fun putting it together.
Next up...a transmission that can hold it!
Old 05-12-2009, 09:20 PM
sdotlog's Avatar
sounds good.
Old 05-12-2009, 09:21 PM
LS1 SPEED's Avatar
congrats on the project coming together
sounds good
Old 05-12-2009, 09:24 PM
robsquikz28's Avatar
that thing sounds wicked man very nice build and should be very stout maybe even a low 11's on motor depending on the rest of your setup
Old 05-12-2009, 09:30 PM
camaroboricua's Avatar
wow that sounds great! congrats on getting it up and running again
Old 05-12-2009, 09:51 PM
94Z28rag's Avatar
Without a doubt...more with some fine tuning and weight loss, IMO.
I'll let him give the specs if he wants...I don't want to spill his secrets...
Old 05-12-2009, 09:52 PM
RamAir95TA's Avatar
Definitely planning on low 11s once I have the transmission worked out. She'll be losing a few pounds as well...I wouldn't rule out 10s.
Old 05-12-2009, 10:19 PM
LT1 Z28's Avatar
how do you like the holly tb
Old 05-12-2009, 11:04 PM
marc97taws6's Avatar
Sounds gnarly!
Good job and Congrats!
Old 05-12-2009, 11:09 PM
SoxXpupPeT's Avatar
holy crap! and i thought mind sounded aggressive! sounds amazing
Old 05-13-2009, 12:40 AM
matt94z's Avatar
Sounds nasty!!
Old 05-13-2009, 01:42 AM
BADMOON's Avatar
Default Numbers?
Let us know man. You gonna be running on pump gas? It looks like a full weight street car just like mine. But I am running less compression 11:2:1.
You gonna tell us the cam specs?
Quick Reply: AI 200cc 383 start-up vid inside.
