Need help wiring in ECU
Old 05-16-2009, 01:05 AM
brianfromhawaii's Avatar
Default Need help wiring in ECU
I am modding my own harness and need some tips, based off of http://chevythunder.com/1999-2002%20...%20pinouts.htm
Which wire needs to be constantly +, which wire needs to be ignition +, why are there so many grounds?
Old 05-16-2009, 05:01 AM
Jones'n's Avatar
4 grounds is a lot? Pin 1 and 40 on each connector is ground (Like the pinout says)
20 and 57 are constant + (Like the pinout says "Battery Positive Voltage")
19 is Ignition + (Again, just like the pinout says)
Old 05-16-2009, 11:40 AM
4 grounds for one device is a lot. is it a failsafe or something?
Old 05-16-2009, 03:42 PM
LS1MCSS's Avatar
If it's a 99-02 harness, there should only be three ground wires that bolt to the back of the head. PM me your email and I'll send you the engine harness schematics.
Old 05-16-2009, 11:20 PM
pm sent
