Anyone in houston have a piston fly cutting tool?
It really seems like these should be easier to find. I need to notch my pistons for 2.02 clearance but should use at least a 2.08 to get the radial clearance I need, probably need to open up the exhaust as its close at just under .100, but the intake was down around .030. I wanted see if someone local has one I can borrow or rent before I go off and try and to make my own cutter from an oversized valve. Even some suggestions one how to do this would be welcome.
thanks.
thanks.
