transmission to bellhousing dowel pins
Old 05-19-2009, 11:28 AM
chi3f's Avatar
Default transmission to bellhousing dowel pins
Does anybody know what diameter and length the 2 t56 dowel pins are that go from the transmission to the bellhousing?
I am at work right now where i have plenty of dowel pins, however i am unsure the size I need.
Please help me out.
Thanks
Old 05-19-2009, 11:55 AM
XtraCajunSS's Avatar
Those dowels have grooves cut into them so that they will seat properly when pressed into the blind holes on the face of the trans. I would recommend using the GM pins unless you can machine the generic pins so that the air can bleed from behind them when pressed in.
Shane
Quick Reply: transmission to bellhousing dowel pins
