transmission to bellhousing dowel pins
Does anybody know what diameter and length the 2 t56 dowel pins are that go from the transmission to the bellhousing?
I am at work right now where i have plenty of dowel pins, however i am unsure the size I need.
Please help me out.
Thanks
Please help me out.
Thanks
Those dowels have grooves cut into them so that they will seat properly when pressed into the blind holes on the face of the trans. I would recommend using the GM pins unless you can machine the generic pins so that the air can bleed from behind them when pressed in.
Shane
Shane
