04 gto alternator in LS1Miata - need help
Old 05-19-2009, 12:44 PM
NRXEB18's Avatar
Default 04 gto alternator in LS1Miata - need help
Does anyone know how to wire in an 04 GTO alternator into a 2000 Miata?
I'm in the final stages of my LS1Miata conversion and the alternator isn't charging the battery. As I look into it; it appears the Alt is controlled by the PCM, but I don't see any pinout points that would work.
Any thoughts & suggestions is appreciated.
Thanks, Ray
Old 05-20-2009, 12:22 AM
mjls1's Avatar
If your using the gto pcm, alternator is seperate from it. Like the 98 camaro I believe. White wire goes to 12 volts battery and brown wire goes to a dash bulb or a 470 ohm resistor then 12 volts iginiton.
Old 05-20-2009, 04:45 AM
NRXEB18's Avatar
I have a volt meter versus a light in the dash. Can I assume the white wire to 12v is the only connection needed?
Old 05-20-2009, 11:26 AM
mjls1's Avatar
You will still need the brown wire. If you dont want to use a light, then you will need to have a 470 ohm resistor and then to 12 volts ign. The volt meter is wired seperate.
Old 05-20-2009, 07:31 PM
downset71's Avatar
brwn wire DEF need that resistor or a marker light pigtail
Old 05-20-2009, 09:00 PM
sm2dan's Avatar
tons of useful electrical information here
http://www.swaptastic.net/ls1_miata/electrical.html
d
