CAM will NOT go in! HELP
Old 11-04-2003, 05:09 PM
gee65's Avatar
Default CAM will NOT go in! HELP
I'm installing a ZO6 cam in my 2001 engine. I bought the cam tool from thunder racing, Igot the cam/spring install from LS1 how to, I have the engine on a stand right in front of me, but this bloody cam will only go in about 80% of the way. I have turned it to the left to the right untill my hand stops working! I have had it in and out six times and I'm afraid to pull it back out again. WHAT IS THE TRICK ?????
Old 11-04-2003, 06:02 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
It should go right in are all your lifters out. Maybe you have a burr on the last bearing somehow from taking out the old cam. And make sure your cam sensor is out so you don't break it.
Old 11-04-2003, 06:31 PM
Tally TransAm's Avatar
make sure one of the lifters didnt slide down a little
Old 11-04-2003, 07:02 PM
DaleMX's Avatar
I had to wiggle mine quite a bit and lift up on it while I was turning it. Eventually it slid right in (cam sensor was removed.)
Old 11-04-2003, 07:08 PM
1dirtyZ's Avatar
try installing it from the back.
Old 11-04-2003, 10:04 PM
Z06PSI's Avatar
lifters probably slipped.... happened to me and then I pulled the cam out a little and dropped a lifter in the Oil pan....
Old 11-04-2003, 10:14 PM
SMOKIN01TA's Avatar
if you used the cam install stuff from thunder properly, you probably just need to make the back lift up to go into the last bearing. it happens alot.
Old 11-04-2003, 10:45 PM
Mike K.'s Avatar
what smokin said you just have to try and picture how the cam is going in and make it perfectly straight. a little wiggling and it will go in, no need to be forceful.
Old 11-04-2003, 10:52 PM
PlainwhiteZ28's Avatar
WTF?
i say try making it more level as said,
or
a lifter is not up all the way
Old 11-05-2003, 07:05 AM
gee65's Avatar
Default Cam sensor ??
Where is the cam sensor ? LS1 how to, instructions never said anything about a cam sensor!
Old 11-05-2003, 07:09 AM
gee65's Avatar
Cam Sensor ? where ?
Old 11-05-2003, 08:18 AM
Glenn98ZM6's Avatar
if its on a stand, roll it upside down to put any "low" lifters back into place.
Old 11-05-2003, 10:31 AM
cyphur's Avatar
i totally agree, flip the engine upside down, it works every time ????
angle the cam slightly(aka wiggle it) and check your lifters...
Old 11-05-2003, 10:51 AM
jmX
jmX's Avatar
The last part is always the hardest, you need to leverage the cam a little bit...put the long waterpump bolts into the cam bolt holes and try to lift up the back of the cam by grabbing the long bolts for leverage.
With the JPR lifter tools, I doubt the issue is a lifter, and I doubt the cam position sensor is the issue too. Its all about getting that angle right to get it through the last hole inside the engine.
Old 11-05-2003, 06:41 PM
LS1swap's Avatar
The cam sensor is all the way in back on the top of the motor by the oil presser sender. Probably sounds like hind sight now, but If you have the engine on a stand you should have turned it upside down that way no lifters can fall. I don't know if I would suggest that now or not? If a lifter falls you have to pull the head.
edit oops I didn't see there were two pages to this post. so mine is kind of redundant. I was also going to say I don't think the cam sensor has much to do with it.
Old 11-05-2003, 07:51 PM
gee65's Avatar
THE CAM IS IN !!! And I want to thank everyone that gave advice. It is so helpfull to have a place to go when you have a problem, you guys are great ! and GOD is GOOD!! The problem was the lifters in #7 cylinder,for some reason Thunder's tool didn't lift them enough( Thunder was very helpful and is sending me a replacement tool) I used two magnetics to lift the lifters just a little more and the cam slid right in !
Old 11-05-2003, 09:28 PM
DaleMX's Avatar
Thats great! Glad you figured it out.
