TH 400 Linkage Adjustment
Old 05-19-2009, 08:25 PM
tee-boy's Avatar
Default TH 400 Linkage Adjustment
What's proper way to adjust linkage (cable driven) on a TH 400? Just did the swap and need help w/ adjusting the linkage. Tranny is a RMVB.
Old 05-19-2009, 09:31 PM
WE TODD DID's Avatar
Adjust it to where 2nd and 3rd gear are dead on.
Old 05-20-2009, 06:48 AM
forcd ind's Avatar
you should have it fit in all postions, sometimes you gotta tweak it bet park and 1st-if the cable is hooked up wrong on like a B&M ratchet shifter (at the shifter) it will never adjust.
Old 05-20-2009, 11:16 AM
2002CAMAROSSLS1T56's Avatar
Originally Posted by tee-boy
Is it ok to adjust w/o fluid in trans?
Yes, it's not going to be running ( I hope not anyway)
Quick Reply: TH 400 Linkage Adjustment
