Will a 305/45/18 M/T ET Street Radial fit on the back of a Camaro w/ Stock Spring?
Old 05-21-2009, 08:12 PM
red01camaroz28's Avatar
Default Will a 305/45/18 M/T ET Street Radial fit on the back of a Camaro w/ Stock Spring?
I'm just wondering if a Mickey Thomson ET Street Radial in a 305/45/18 would fit on a Camaro? It's 28.8" tall, and 11.8" wide. I know I would probably have to run a stock rear spring. Thanks
Old 05-21-2009, 09:12 PM
sr71's Avatar
would it fit???.....yes. but, it may take a little coercion with the bfh.
would it look like crap???.....yes. unless you had a set of 26" skinnies on the front.
Old 05-21-2009, 10:17 PM
Lt1Porsche's Avatar
I dont understand why it would look like crap? Care to elaborate?
Old 05-21-2009, 10:19 PM
Lt1Porsche's Avatar
If instead of the 45 sidewall what about the 35 sidewall. Does anyone know if the 35 sidewall would offer enough flex to get a launch on?
Old 05-21-2009, 10:25 PM
sr71's Avatar
since a picture is worth a thousand words, I'll save myself a thousand words or so. look at the first pic in this thread. https://ls1tech.com/forums/wheels-ti...h-radials.html
see how bad a 2" mismatch in diameter looks with wide tires on all 4 corners??? now a drag set up, on the other hand, looks badass with a wide 28/ narrow 26 combo.
Old 05-21-2009, 10:51 PM
Lt1Porsche's Avatar
Okay but those are M&H tires. The Mickeys will look a lot wider and I feel will give it a better stance.
Old 05-21-2009, 11:24 PM
sr71's Avatar
width doesn't affect stance, only diameter does. and those mt's are almost an inch taller than the m&h's. the diameter difference will be even more pronounced. I had the same thought as you UNTIL I saw that pic. I'm glad I didn't spend the money.
