What fuel pressure Regulator that rises with Boost/1000rwhp/what are you guys running
Looking for a fuel pressure regulator that rise with boost good till little over 1000rwhp
Wondering what some of the guys here are running for the Regulators. Im just about to do the MM dual pump setup on the cheap
Plus what the max PSI that can be run on the 60lbs injectors?
