sts turbo need your input!!!!!!!
The heat of the exhaust is one thing that helps seal the turbo. When the heat is applied through the turbo, the clearances get closer and therefore the turbo performs better. When STS put the turbo in the back its not subject to the heat and therefore the clearances are just as if the turbo was cold. Plus, if this is a DD, what about rain? Splashback? The turbo does get some heat to it and what happens when you dump cold water on hot cast? It cracks. And, think about what if your filter gets wet, sucks water into the turbine thats spinning about 20K rpms? Water to turbine blades spinning that fast is like throwing sand into the turbine, not good. Another thing to consider is what if that oil pump fails? your engine will still be pumping oil to the turbo with no way to return to the oil pan. then guess what, you're spinning bearings because of lack of oil in your engine!
I would keep looking for something that is closer to the engine and naturally drains to the oil pan. There are tons of LS1 kits available that may cost more, but I tell you one rebuild of your engine because of a stupid pump failure will cost way more then the extra 1-2K spend on an underhood intercooled system.
Still need to fab up a snorkel for the air filter like the newer sts kit, but my emissions evap canister is in the way. I'm going to put in stock exhaust tips with the wastegate going to the drivers side tip. Maybe even cut up a muffler to make a shield to hide the setup from behind.
I could have slapped it together in a week or two but I like to do things nicely so I don't have to worry about problems later.
Everyone has their own opinions of STS of course but with and kit you'll have some type of issues to address. But with the amt. of experience we STS guys have now and the amt. of pointers we have to do it right the first time it makes it easier on newbies(no offense)to STS/rear mount.
I'm running the gt67 with fmic with typical upgrades to fuel and tune and love it. I thought about the water issue to and live in florida and see a decent amt. of rain and have never had a problem! The kit comes with a filter sock that can be easily installed when it does rain a decent amt.
The only issue Uve had out of the kit at all is my connection to the top of the remote oil pump came loose(due to my own neglegence) and sounded the low oil psi buzzer and flooded the turbo with oil. Which I tore apart the turbo and cleaned. As far as oil related issues if the pump does fail you will know it does because of the oil psi buzzer so I dont think that you'll hurt an engine due to this with this style set up.
In the end run a search on rear mounts/STS and you'll find alot of good info and opinions.
https://ls1tech.com/forums/forced-in...bo-system.html
