Has anyone had a WOT switch stick?
I am wondering if anyone has ever heard of a WOT switch sticking open or have had it happen to them. A friend of mine says he had it happen to him and it bounced off the rev limiter for a good minute before he got it shut down. A week later and he had a rod knocking so he insisted to me to not use a WOT switch and use a push button switch instead. So what do you guys think? i will use a WOT no matter what but do you think there would be added safety in using a push button switch on top of that?
If you are concerned about your system remaining activated because a WOT switch failure, just use the wiring diagram provided by the nitrous system's manufacturer.
Every brand I know tells you to use an arming switch (in series with either WOT or pushbutton). If something goes wrong, just deactivate arming switch and the whole system will turn off.
Regards
