would this help body rigidity
http://www.ragingmotorsports.com/productgroup.asp?33=99
check out this 6 point cage.... do you guys thing this would help out with body rigidity? does any one have this cage already? good bad other?
It will help with rigidity. A properly deisgned cage will have a bigger impact on rigidity than anything else you do to your car. A 10pt cage will do more than a 6pt. A 12pt is more effective than a 10pt you get the idea.
Keep in mind that generally the more "points" a cage has the less convenient it will be to get into and out of the vehicle.
Do a search for NataSS (I believe) if you wanna see a serious cage. He posted some pics awhile back.
Kev
cool thanks
i dont think i want to go to crazy cage wise i figgued the 6pt. was just the right speed... i was just wondering if it makes a noticible diff or not.
