Mazda RX-8 LS-1 swap
Old 05-28-2009, 10:48 AM
Motorstilling's Avatar
Default Mazda RX-8 LS-1 swap =VIDEO=
Here are a few pictures of our project.
It is running but there are few things that needs to be sorted out.
This RX-8 had a blown engine so this swap was the most obvious thing to do.
The engine comes out of a 2004 GTO.
Old 05-28-2009, 11:03 AM
rao
rao's Avatar
Nice!
Those rotaries are always blowing up . The folks at www.v8rx7.com would be very interested in this swap.
Old 05-28-2009, 11:43 AM
383lt1impala's Avatar
That's bad ***!!!!
Old 05-28-2009, 12:00 PM
Convette's Avatar
Is that the stock rx8 rack and pinion? Also what drive shaft are you using?
Old 05-28-2009, 12:08 PM
KINTARO's Avatar
what headers and oilpan
Old 05-28-2009, 12:11 PM
firechicken76's Avatar
HELL YES, do you know how long ive waited to see this? any video?? how hard was it? how did the Renesis blow? I used to own one of these cars, they are guttless, glad to see something being done to fix that!!!
Old 05-28-2009, 07:20 PM
finiata's Avatar
Does the shifter fall in the correct place? Were the mounts a add on to the existing subframe or a new subframe?
Old 05-28-2009, 07:39 PM
NemeSS's Avatar
dam that looks rigth at home
what oil pan, mounts, etc.? any more info?
Old 05-28-2009, 07:47 PM
probably gonna need a new rear end?
oh no, they threw off the 50/50 distribution, now it wont be able to corner jk
the rotards are gonna throw a fit when they see this.
interested in the weight of the car also
Old 05-28-2009, 07:48 PM
b005td's Avatar
werd
need more info
Old 05-28-2009, 08:17 PM
NMJ87T2's Avatar
That looks fantastic! We must have more info though.
Old 05-29-2009, 07:45 AM
We drove it for the first time yesterday.
It has plenty of power
The gearing is very low, we are using the stock 4,44 differential.
First gear is almost useless.
We are using a Camaro steering rack and oil pan.
And there are no gauges yet, the 8 uses CAN bus cluster so I think it is impossible to use it with this setup.
Old 05-29-2009, 08:01 AM
Snyper's Avatar
My 350z uses the same setup and Im using a CAN gateway. As much as I dont want to say this you should contact Hinson Super cars and see if they can help.
Old 05-29-2009, 08:30 AM
You are using the LS2 wich has a CAN bus system, right ?
Old 05-29-2009, 08:40 AM
MyLS1rx7's Avatar
Sweet! I have been waiting to see somebody do this for years...
Old 05-29-2009, 08:45 AM
jmilz28's Avatar
Same here! This is indeed an obvious swap, hope you can kit this. This thing handles and has a useful back seat. May want to do something about the gearing to make first gear workable. The GTO tranny has different ratios, so that's only making first worse.
AWESOME SWAP! Video!!
Old 05-29-2009, 09:02 AM
OMGWTFBODY's Avatar
Baller.
Old 05-29-2009, 09:16 AM
Snyper's Avatar
Yes. But im not using the CAN lines for the readings. My speedo setup is independent. It takes readings right off the rear end. The tach had to be spliced in using the Can gateway though.
Old 05-29-2009, 11:42 AM
need video!!!!
Quick Reply: Mazda RX-8 LS-1 swap
