3 wire -> 1 wire Oil Pressure Sensor?!
Hey guys,
Swapped an LS1 into my 2000 S10, and a nice t70 turbo on the back of it.
The engine is out of a 98 vette. It has the 3 wire oil pressure sensor.
My harness from Current Performance (made by Jared) has a single wire o2 sensor plug.
Can you connect the single wire to one of the 3 wires in the 3-wire-Sensor to make the gauge work?
I don't want to have to go buy a new sensor...
3-wire sensor has:
Grey wire= 5 volt source
Tan/wht wire=Signal
Blk = Ground
Right now, i have it Tee'd into the Tan/wht wire. Oil pressure guage is pegged (reading 100+psi) without engine running.
Can this be done? hookin it up to one of the other two wires?
3-wire sensor has:
Tan/wht wire=Signal
Blk = Ground
Way different threads. The S10's threads are way too big. The LS block's threads are very small.
Russ
