How to bypass the clutch switch??
Old 05-28-2009, 05:56 PM
adam120674's Avatar
Exclamation How to bypass the clutch switch??
How can bypass the clutch switch to see if it is broken? Popped the clutch now I can not keep it running. May have broken sometime inside it. It still making contact. I KNOW THIS IS A SAFETY DEVICE!!! Just want To see if it is the problem and not have to wait on it to get here(no store around here has them, have to order)Thanks for any help
Old 05-28-2009, 07:19 PM
z_speedfreak's Avatar
are you talking about the one behind the clutch pedal? if so just take it out, I don't have one anymore
Old 05-28-2009, 07:36 PM
adam120674's Avatar
thanks, but I thought u would have to jumper it somehow?
Old 05-28-2009, 07:41 PM
DONAIMIAN's Avatar
Disconnect the switch and connect the two wires. Done.
Old 05-28-2009, 07:50 PM
adam120674's Avatar
But there are 4 wires going in to the switch
Old 11-04-2009, 10:48 AM
Syclone354's Avatar
Bump on this. I am trying to find the same info on my 05 cts-v, i believe the clutch safety switch has gone bad. Car does the same thing disconnected or connected, will not crank when key is turned. Fuel pump is running and all other functions are normal. Car does have a 4 wire switch.
Old 11-04-2009, 12:44 PM
Spartan7's Avatar
He was probably looking at the wrong switch. There are only 2 wires going to it, and the switch simply completes the circuit. So just short the 2 pins to bypass it.
EDIT: That's for an F-body, not sure about a CTS.
Quick Reply: How to bypass the clutch switch??
