Difference in ls1 and ls2 shifters
I just purchased a tranny for my 2006 ls2 gto and It was a rebuilt tranny but I can't seem to get it to go into 2nd4th6th I dno if the shift linkages are different could it b a ls1 tranny or did I do somthing wrong
so i pulled the shifter off of the tranny and with the shift rod and shifter set in neutral the bolt holes do not line up and when i line up the bolt holes the shifter leans back like its in 4th gear? I know i have a ls2 shifter on the tranny but do not know what this tranny came out of. I was told it was a ls2 tranny but im starting to think maybe its a ls1 t56 could that be my problem? I was thinking bout just buying a short throw for a LS1 and seeing if that fixes my problem
The shifters for the GTO have an offset that mounts them back far enough to fit the opening in the tunnel. A F-body style shifter will not work without some sort of offset handle adapter. As far as I know, the T56 trannys are the same between the LS1 and LS2, other than the gear ratios. Are you using the stock GTO shifter?
Well i do not have the old transmission do you have any idea where i could get one of those at? Im tired of messing with it and would like to have it running correct
