Anyone else experience this? What could be causing it?
Old 05-28-2009, 10:36 PM
Stroker2112's Avatar
Default Anyone else experience this? What could be causing it?
Not sure what's causing this...maybe someone else has experienced this and found the culprit? Basically, there is a studder in my trans (4L60E) during part throttle acceleration, in 2nd gear only... it happens between 2000-2500rpms every time. It studders only for a split second and then continues to shift later into 3rd, 4th as normal as I accelerate. I've pointed this out to my tuner but he never sees it on any of the data logs. Has anyone experienced this and what was the culprit in your trans?
Stroker2112
