What CI would this make?
Ok I know there was just a thread w/ a link to a calculator to figure out what CI a motor would be by Bore*Stroke. If some one could post this link or let me know what this would work out to be....
Bore 4.080
Stroke 3.622
Also does increasing the bore size increase or decrease compression? I would be using LS6 and don't want ungodly compression.
Bore 4.080
Stroke 3.622
'bout 378 ish..
http://www.ring-pinion.com/calculato...latorsind.html
bigger bore = more air to compress and more compression. small chamber heads add up the compression quick. partially why bigblocks have HUGE chambers.
