Changing clutch fluid
Old 05-30-2009, 02:19 AM
Ironxcross's Avatar
Default Changing clutch fluid
Is there a write up on this? I'm looking to do the drill mod, but I need to change out the fluid anyway because its old.
Old 05-30-2009, 11:17 AM
Ironxcross's Avatar
anyone?
Old 05-30-2009, 09:03 PM
slayerized6's Avatar
installuniversity.com for drill mod write up.
just search "how to bleed hydraulics" in the search for how to bleed the clutch. you can either do:
the old fashioned 2 person (1 pumping the pedal, 1 opening the bleeder)
1 person method (drill a hole in the trans tunnel and pump pedal/open bleeder with one person
or the you could use a mityvac
Old 05-30-2009, 09:12 PM
the_merv's Avatar
Drill mod is easy bro, you just have to take out the Master to do it. That little procedure can be tricky..
Quick Reply: Changing clutch fluid
