let's hear horror stories from people who bought assembled engines
Old 05-30-2009, 11:08 PM
blkdkz28's Avatar
Default let's hear horror stories from people who bought assembled engines
anyone dropped five or six grand on a new motor and had it break after a few thousand miles?
I wanna hear your stories!
Old 05-31-2009, 08:45 AM
philip052374's Avatar
i bought a 383 sbc shortblock from rpm machime in tn(bought it off the internet). had a hell of a time getting it to run worth a ****. finally got it running good, was tuning the carb in the driveway and my neighbor came over and said "hey man, you have water leaking out from under the car". you guessed it, 3" long crack in the block !!! the block is sitting on the floor in the garage. turned out to be a blessing, because the bearings were too tight and were starting to f'up the crank journals. had a local machine shop polish the crank and machine me a new block.....it is sitting on an engine stand in the garage waiting to go back into my 91rs camaro.
Old 05-31-2009, 08:53 AM
got-a-ls1's Avatar
wow... good news all around from that builder huh? id be getting my money back if this was recent. they obviously never checked bearing clearances and how could any shop worth a damn not find a crack in a block.
Old 05-31-2009, 10:17 AM
blkdkz28's Avatar
that's crazy. I'd be super pissed
Old 05-31-2009, 03:09 PM
05gto60's Avatar
ive got a nice story about a former sponsor here (WRE) but i dont have the time it would take me to type ALL THE CRAP that was wrong with my motor. one of the things was low oil pressure for a brand new motor (15PSI hot with rotella t 15w-40). they tried to say the the almunium SLP pump would expand soo much, it caused the drop in oil pressure no, their crappy build caused the low oil pressure cause oil pressure was low even on a cold start (like 40-50psi). if it was the pump expanding, it should have been in the 70s like my current motor now on a cold start and then slowly falling to 15 as the motor got hot. oh, and apparently i added material to the main journals, cause they said the main clearances were tighter than they set them to. and not to mention the half @$$ed repair job of my AFR heads
Old 05-31-2009, 09:05 PM
FiredUpZ28's Avatar
wow thats nasty... keep em comin guys!
Old 06-01-2009, 08:01 AM
Steve Gunn's Avatar
I bought an MTI (out of business-Texas) forged 347. Had low oil pressure, lots of noise. Pulled it out, sent it back. They said it spun a cam bearing and they fixed it. Put it back in, same ****. Low oil pressure, valvetrain noise. I said "f" it and ran it because I was now broke. It made 383/375 at the wheels for a heads and cam car. I finally had enough and recently pulled it out. The cam bearings were improperly installed. The front one walked back and the lifter actually put a half moon hole in the bearing. everything was oil starved and the only parts reusable in the rebuild were my heads and crank.
Old 06-01-2009, 10:13 AM
blkdkz28's Avatar
damn they did you dirty. anyone else?
Old 06-01-2009, 12:34 PM
dlandsvZ28's Avatar
This will make you puke.
A sponsor on this site - but a few years back did this work. They did a h/c long tube bolt on build for me - nearly 10 grand. Part of the build was their special ported new heads. He showed me both heads before the install in a new box. Both were shiney new. I was impressed.
Because of a very noisey valve train even with the Yella Terra's another shop decided to pull the heads at around 2500 miles because the original shop had went of of business.
This is what one head looked like. I can only go by what the second shop said - not a new head for sure since I had driven the car less than 2500 miles. I suspect my heads went somewhere else and I got some used heads off of the shop owners car.
http://www.flickr.com/photos/1835930...7602956888623/
We also pulled out a very loose supposedly new Vig 3600 TC. I sent it back to Precision Industries for a restall - their stamped numbers on the TC identified the TC as a 4000 stall with a purchase date far before I had ever made arrangments with the shop to do any work for me.
Because of the shoddy work there is nothing left from this original build except the Comp cam, oil pump, YT rockers, and LS intake. I have had to replace everything else such as heads, pushrods, TC, LongTubes, rebuilt A4 that failed on highway only 7000 miles, and retuning.
Ten grand down the drain plus all of the labor and parts replacing junk from the first build.
Old 06-01-2009, 01:28 PM
novaflash2002's Avatar
my buddy ordered a tsp l92 427. put it in boke it in and drove it for 6000 miles, and finaly put synthetic oil in it, about 200 miles on synthetic it spund no 6 rod bearing. I and 6 (yes 6) other machinists, inspected the engine, and noticed on the crank, that the oil fillet holes were very shiney. the crank had never been polished so it had high spots, well after those polished them selves down it had way too much clearance. moral of the story dont buy a mass produced engine, they go for quanitity not quality. he lost a litlle over $5000 id say
Old 06-02-2009, 10:29 PM
Steve Gunn's Avatar
Old 06-03-2009, 03:41 PM
musclecity85's Avatar
i bought a "suppose to be running" lq4..got it tore down by the machine shop..block was cracked..and the cank journals worn the hell out! soo needless to say i replaced everything but now something came up so my funds are gone n now i have to sell everything!
Old 06-03-2009, 04:15 PM
Viper's Avatar
Had a motor put together by a shop no longer in business (JPR) and it died at about the 10K mark, nothing salvageable except the heads. Valve dropped and blew a hole in the piston then went south from there.
Old 06-03-2009, 06:16 PM
Black FormulaLs1's Avatar
i got a dyno tune in savannah georgia and about 3 weeks later spun a damn rod bearring, so i bought a long block, had it rebuilt w/ h/c/forged internals etc..and no issues yet..just needs some dyno time..
i lost out on $500 for the shops dyno time, and $1300 for the longblock..
Old 06-04-2009, 02:20 PM
john563's Avatar
can you pn me the sponsor as I will be shopping this fall
Old 06-04-2009, 02:29 PM
dlandsvZ28's Avatar
He is out of business so unless he has started a new business I don't think you will encounter having to worry about this shop.
Old 06-05-2009, 12:04 AM
02BLKWS6MD's Avatar
where are you from? We had a shop like this here in MD. My favorite one they did was nut and bolt a convertor on a flexplate for a Turbo 400 car. There were plenty of stories but I thought I'd share the funniest one because it destroyed the input shaft on the tranny.
