making lifter tool with 5/16 rod?
Old Feb 19, 2009 | 11:36 PM
lilred1995vette's Avatar
Default making lifter tool with 5/16 rod?
Besides making tips on them, do i need to make a flat side on them like the 100 dollar ones?
Old Feb 20, 2009 | 09:01 PM
S10xGN's Avatar
Might not hurt. Using 5/16" wood dowels, my DR side slid right in as-is,but the PASS side had to be tapped in with a hammer. Maybe sanding a full length flat would be the ticket...
Russ
Old Feb 20, 2009 | 10:31 PM
HavATampa's Avatar
Thumbs up
Yup...I ground a flat the full length one of the metal rods I made a few years ago. Used them again tonight and they worked like a charm. Not sure why the passenger side is different?
Old Feb 20, 2009 | 11:55 PM
jrpimp00's Avatar
What length are you guys making them? I need to make some for my install
Old Feb 21, 2009 | 12:03 AM
HavATampa's Avatar
Mine are about 20" from the tip to the bend (handle).
Old Jun 3, 2009 | 07:01 PM
Ford_Assassin's Avatar
Any reason 5/16" brake line tubing wouldn't work too? Then you could just tap out a flat side if needed.
Old Jun 3, 2009 | 08:45 PM
01formula6's Avatar
Just buy some 5/16" wood dowels at HD, lightly sand them 100% smooth, coat in oil and enjoy I've used mine 3x now and they work great.
Old Jun 3, 2009 | 09:17 PM
bigboykilroy's Avatar
Thats what i use and it works great !
Old Jun 3, 2009 | 11:37 PM
frankmarroquin's Avatar
Becareful with the wooden dowels... I used mine several of time but I'd haveto say after the about 10th time the unfortunate happen.... One of them broke in the driveside hole. I had to drive a screw into the dowel itself but at the same time being careful that I didn't the lifter and wala it came out. Was really damn scray though. LOL it funny now but wasn't then.
Old Jun 4, 2009 | 12:20 PM
01formula6's Avatar
Hmm you make a good point. I wouldn't be laughing if that happened to me....those brake lines do sound good
Old Jun 4, 2009 | 07:39 PM
venom99's Avatar
what are these for
Old Jun 5, 2009 | 03:50 AM
SOMbitch's Avatar
Originally Posted by venom99
what are these for
To hold up the lifters during a cam swap.
