Overheating at idle
Old May 17, 2026 | 05:06 PM
Q1king's Avatar
Default Overheating at idle
Hi all,
I recently bought a ’97 Trans Am, and it’s been running fine overall. I replaced the thermostat, flushed and refilled the coolant, and properly bled the system. However, it has started overheating at idle or when stopped at a light. On the highway, it stays at normal operating temperature with no issues.
This just started today. It’s about 90F outside, and every other time I've driven it, it's been a cooler day.
Any help or advice is appreciated.
Old May 18, 2026 | 08:33 AM
shbox's Avatar
Define what you call overheating. Have you used a scanner to look at PCM reported temps and checked for fan operation when they are commanded on?
http://shbox.com/1/4th_gen_tech2.html#cooling
Old May 18, 2026 | 08:59 AM
Q1king's Avatar
So the PCM reports back 106c/223f. The gauge shows that it's close to the red zone.
Old May 18, 2026 | 12:20 PM
irocbsa's Avatar
223F is perfectly normal while sitting and idling on a hot day. The sending unit, wiring, or the gauge itself might be failing. The sending unit is on the driver's cylinder head between #1 and #3.
Old May 18, 2026 | 12:40 PM
Q1king's Avatar
Yeah I think it might be the sending unit. I'll swap that and report back.
Old May 19, 2026 | 08:21 AM
shbox's Avatar
I don't see any problem. If it gets above the threshold for the fans to come (226°) on and they don't, then there is an issue. The gauge seems to be acting normal for this car.
Old May 22, 2026 | 04:46 PM
Q1king's Avatar
Update: replaced the thermostat, both the temp sender, and sensor and the fuse is more steady now but the gauge still bounces a bit
Old May 23, 2026 | 12:12 PM
Q1king's Avatar
Nevermind it's still exhibiting the same issues as before. Temp shoots up and says check gauges
