No Reverse!
Old 05-31-2009, 06:40 PM
jusTAnother's Avatar
Default No Reverse!
My car will not go into reverse. It only goes over far enough to be even with 5th and 6th gear. Im thinking it is my reverse lockout. Is there a easy way to check it?
Old 05-31-2009, 06:44 PM
bearcatt's Avatar
Hopefully it's only your reverse lockout solenoid or Engine Control Fuse that gives it power.
Otherwise ....
Old 05-31-2009, 09:40 PM
the_merv's Avatar
LS1Tech 10 Year
It will go in, you can over-power that Solenoid by hand.
I just finished my T56 Swap and don't have mine tuned for the T56 yet so I've been doing that for a while now..lol
Old 06-01-2009, 07:40 AM
how hard is it to over power the soleniod? It feels like i am hitting a wall.
Old 06-01-2009, 08:27 AM
02BLKWS6MD's Avatar
Just use your knee to push it, makes it alot easier. Did you replace the clutch or have the trans out? I just did a clutch swap on mine and bent one of the pins on the lockout and the reverse lockout wouldnt work. And that solenoid not cheap either.
Old 06-01-2009, 12:01 PM
I did just replace the clutch and slave. I am hoping the plug for the solenoid is not in all the way but I wont find out until this weekend. she is going in the bodyshop today after work.
Old 06-01-2009, 05:21 PM
the_merv's Avatar
LS1Tech 10 Year
It'll feel like that normally..just give it a good push or smack your hand with your other hand, you will know when it clicks over.
Quick Reply: No Reverse!
