No Reverse!
No Reverse!
My car will not go into reverse. It only goes over far enough to be even with 5th and 6th gear. Im thinking it is my reverse lockout. Is there a easy way to check it?
Just use your knee to push it, makes it alot easier. Did you replace the clutch or have the trans out? I just did a clutch swap on mine and bent one of the pins on the lockout and the reverse lockout wouldnt work. And that solenoid not cheap either.
I did just replace the clutch and slave. I am hoping the plug for the solenoid is not in all the way but I wont find out until this weekend. she is going in the bodyshop today after work.
