Help--Wont start
Help--Wont start
I've got a 2001 ls1 and 6 speed in my 70 camaro. I am trying to get it started for the first time with no success. I have went in with Hp tuner and turned off VATS. I am getting help from the guy that sold me the Hp tuner but we are running out of things to check. I have power and ground to the PCM. I have power to the injectors and coils. I have good fuel pressure but the injectors aren't getting their ground signal from the PCM. If any body has any suggestions of what else to check I would sure appreciate the help.
I am not getting any codes. I was getting a fuel tank pressure code and a code for egr but those have since been turned off. I brought up the gauges with the scanner and when i crank the engine i am not getting any data, RPM, INJ % or anything. I dont know if i am doing something wrong or if ther is a problem.
Some times you will loose comunication due to cranking voltage issues and is normal, sounds like you have a security issue still. Are you sure the VATS is removed? It is a very simple system to by-pass.
