For those of you with the Taurus fans or 2 speed fans, step inside
Is there a way to use the stock wiring with a different relay and only run the high speed without having negative effects on the wiring? I'm not worried about the fan, I'll just buy a new one of those if it burns up.
I know it requires an 80 amp relay or so, so is there an 80 amp relay that will fit in place of the stock relay?
Or is there a better way to go about this? I seen a 70 amp relay kit for 59 bucks plus shipping, just not really wanting to spend that much on the fan setup that I don't know if it will keep the car cool or not.
All I'm concerned with is having the high speed. I found something that said to use a Bosch 150 amp relay p/n 0 332 002 156, but I can't find that one. I'm assuming I'd still be able to control the fan by splicing into the pcm pinouts, just not sure how to go about it. I know someone has done this
Hmm.
I have a Taurus 2 speed, wired for high only. It runs off the stock PCM with a 40 AMP relay and a 40 AMP fuse in my stock (RX7) under hood fuse block.
I -used to- cook relays, wiring and fuses with a 60 AMP fuse, 10 gauge wire and dual 30 AMP relays; then I replaced the old ***, worn out stock motor on the fan with a fresh one... whaddya know, no more issues.
From what I've seen, it's closer to 3000 CFM on high. Mine keeps a 17x19x1.5" single pass radiator cool enough to handle a turbo LS1 in a tight engine bay in traffic, in 90* temps. Engine stays under 200*. I do have a LOT of shrouding though.
Hmm.
