Western Members CA, AZ, NV, UT, CO, NM, HI
Caliper Covers for F bodies in stock & Stealth Shift light
Old 06-11-2009, 12:21 AM
Stroker396@APF's Avatar
Default Caliper Covers for F bodies in stock & Stealth Shift light
Hey Guys, We are the first to have these in stock for F bodies. They are a nice touch to clean up the look of the ride and cut down on brake dust on the rims.
Regular Price is $199.99
Sale Price is $179.99
Free Shipping in June!
Reduces Brake Dust
• Powder Coated Finish
• 6061-T6 Aerospace Aluminum
• No tape, glue, paint or special tools required
• Patented Fastening System
• Easy Installation
Available in Red, Black or polish Aluminum
This is not the same car, just a cool pic I got from my event at a friends shop
https://ls1tech.com/forums/sponsor-g...02-f-body.html
Don't like the look of a big shift light mounted where it looks out of place?
Then mount one of these!
The powerful LED is bright enough to be seen in daylight
It is available in Red, Green, Yellow or Blue
Cost is $105 ($110 for Blue)
The LED and cord are separate $10
RPM Activated Switch The rpm activated switch, is an easy way to add a single LED shift indicator to your vehicle for the ultimate stealth installation. It can also be used to trigger external devices either on or off, at a set RPM. One Normally open contact and one normally closed contact rated at 2 Amps.
Also Available is the Dual Mode Shift light
Make your launch consistent with the aid of a dual mode launch/shift light!
Our newest edition of shift lights for 2008, incorporates a launch feature as well as the features in our standard shift light. This model allows the user to set a desired launch rpm, upper and lower launch limits, pulse/rev, and shift point setting. Stand alone operation!
Uses the signal to the speedometer or the Vehicle Speed Sensor Signal to determine launch or shift mode.
Example: Program the launch to 3000 rpm, +/- 200 rpm and shift point at 6200 rpm. This effectively creates a launch "window" of 2800 rpm to 3200 rpm. If the vehicle is staged (not moving) the unit enters into launch mode automatically. If the rpm is under the lower limit of 2800 rpm, the LEDs are off. If the rpm is above 3200 rpm, the LEDs flash rapidly. However, if the rpm is within 2800 rpm and 3200 rpm, the LEDs are on constant. So the user simply brings the engine rpm up until all LEDs are on. This keeps one from looking down at the tach trying to keep the tach needle to the desired launch point. After the launch, the unit automatically disables the launch mode and enables the shift mode, where it will come on at 6200 rpm in this example.
If you choose to not use the launch feature when your not at the track, simply press the program button twice within one sec to disable the launch feature. When your ready to race again, simply press the program button twice within one sec to re-enable the launch feature.
Available in four LED colors. Seven bright LEDs visible in direct sunlight. Easy wire-up: 4 wire connection. With the supplied ten foot long black cable, you don't need to add extra wiring.
RISC processor for extreme precision and easy user interface. Simply press and hold the program button to enter into program mode, where you can set the desired launch rpm, launch limits and shift point setting. The new settings are then stored in memory. Program mode 2 allows you to set the pulse/rev, etc.
Dimensions: 3.625" long x 0.75" diameter. The most compact shift light of any manufacturer! Allows you to mount it virtually anywhere within the vehicle, even in the AC vent for a hidden but effective shifting tool.
Two different style Mounting Brackets. Vinyl covers are for reducing emitted light intensity for night racing. They do not determine the color of the emitted LED light. Covers match the LED color.
**Note** Will not work on cable driven speedometers!
$125 (Red, Green or Yellow Leds)
$130 (Blue Leds)
Old 06-11-2009, 12:55 AM
CaliforniaBoy5's Avatar
Originally Posted by Stroker396@APF
Damnit, that car looks familiar!
Old 06-11-2009, 10:03 AM
383lt1impala's Avatar
I wonder if those covers will fit my impala?
Old 06-11-2009, 04:45 PM
topfig1's Avatar
I have a red set on my G8 and they look great!
Old 06-11-2009, 08:42 PM
Dan
Dan's Avatar
How about dark blue?..How long is the sale going on??? End of June?
Old 06-11-2009, 08:47 PM
They are powdercoated, right now they are not doing dark blue. They will do custom engraving for $100 and put what you want on them (so long as it does not infringe on a copyright or trademark)
They will paint them and color match for $100 as well. For you Dan Anozided Blue would look cool
Old 06-11-2009, 11:30 PM
Arc00TA's Avatar
These look really cool, can you describe how they are mounted at all? My calipers look like poop and this would be way better than painting them if they're easy to put on.
Old 06-11-2009, 11:45 PM
I can tell you breifly, they came in just before invasion and I really have not had a chance to look closely at them.
There is a peice of metal that goes across the top of the caliper and it has a small threaded flush bolt that protrudes, I believe a clip goes on the other side and bolts to it. But again I have not even got my set yet.
I am looking forward to it because I rarely get time to clean the rims and that should really cut down on the brake dust, while improving the look.
Old 06-11-2009, 11:57 PM
Arc00TA's Avatar
Whats the turnaround on orders? I'm going to deploy beginning of next month I don't want to order a set and then not be around to get it.
Old 06-12-2009, 12:01 AM
We just got them in stock the other day. Takes about a day to get to Deigo.
Where ya going the Sandbox?
I will be in Austrailia next month to ambush some Jarheads (op4)
1st exp force to be exact haha
Quick Reply: Caliper Covers for F bodies in stock & Stealth Shift light
