Suspension Guys, put subframes on the car=hard as Heck to hook
99 Camaro cam car, bone stock suspension went 1.52. Put subframes on the car cause I don't want leaky t tops and this sucker is hard as **** to hook now, now this is on the street. I finally got it to hook somewhat but I still lightly hazed the tires and that was on 14psi...lol. I'm sure I could hook on the track but I need this baby to hook on the street as well. I have some lca's and lca relocation brackets that I just haven't put on yet. I'm on a 275 mt drag radial, looking for some 15x10 so I can run a 325. What should be next on my suspension list? Torque arm? Shocks...or???? Thanks.
Thanks for the info. Like I said I hav ethe lca's and relocation brackets just have to throw them on. Gonna go with a torque arm next I believe. What do most people run as far as rear shocks? I've heard of people just going with the cheapies in the back and getting good results?
6 & 8 Second Club
Don't forget the tiny bit of slop in the car might have been softening the hit.
As you add stuff, it get's stiffer & the power hit's the ground a little quicker & harder.
When you have eliminated all body flex, roll, slop, ect, it's going to be like pow, instead of blam.
Just a thought. Plus it's the street, maybe they didn't scrap & spray that day??
Thanks guys. Gforce put them on so they were done right. I know i will get the car to hook its just a matter of putting the pieces together in the right order. Ta will be next along with some rear shocks. On there umi relocation brackets should i use the bottom hole or the top hole? thanks again
